Material IDs on separate layer in EXR?
hyperviktor
hyperviktor
I am trying to render material ID mattes for compositing. Cryptomatte works well but all material IDs will be on one layer and it's almost impossible to key values for comping.
Is there a way to store IDs on separate layer ?
Or any other way to render material ID passes separated for compositing ?
CiroCardoso3v
mpowers
In that post, I shared some materials in a material library and a max scene which you might find helpful.
I use AfterFX for compositing. Use the cryptomatte effect, select the object, then choose matte options from the drop down. You shouldn't have to key anything.
Mike Powers
Director of Animation \ Cramer
[email protected]
https://vimeo.com/mpowers
3DBOXX W8920Processor 32.0 GB RAM
Dual Xeon CPU E5-2670 0 @ 2.60GHz, 2601 Mhz, 8 Core(s), 16 Logical Processor(s)
Windows 10 Enterprise - 1809
NVIADIA Dual RTX2080TI 11GB V 419.35
hyperviktor
I need just the opposite - separate mattes on separate layers.
