Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
How to see text transparent in 3ds max using Arnold
4 REPLIES 4
658 Views, 4 Replies
Please help me
Tags (1)
Labels (1)
4 REPLIES 4
Please help me
madsd
Use an OSL Bitmap lookup, wire the RGB to the base color and the A ( Alpha ) to the Cutout slot on the physical material.
i don't know nothing about OSL bitmap
I need to see the texture through text in 3ds max
Please help me
madsd
That is not transparency.
You need to composit the text bitmap and the other texture, using something like "Soft Light" blending mode.
So you take your 2 bitmaps and stack them in an OSL Composit node.
If you set the viewport to HQ mode and the same for the material, it will also show in the viewport.
