How do I invert an operator selection?
n_rehberg
n_rehberg
I've got a standin that contains lots of procedurals all pointing to the same ass file. (i.e. vegation files where one standin is scattered around a lot)
When I set the visibility of one item per operator it works fine.
But for layering purposes I would also need to invert a selection. But no matter what I try this always leads to all items to be hidden.
I tried to use "not /aiStandIn1/aiStandIn1Shape", "* and not /aiStandIn1/aiStandIn1Shape" or even "*.(name != '/aiStandIn1/aiStandIn1Shape')" and some other ways to get to them,
but no matter how I try to invert a selection it always hides all spheres.
What is the correct syntax here? Or is there a problem doing this with procedurals inside the standin?
Nico
Stephen.Blair
With just that "not /aiStandIn1/aiStandIn1Shape"", you're selecting the container standin too. Plus the polymeshes loaded by the other standins.
/aiStandIn5/aiStandIn5Shape is my container standin (it loads five standins)
This worked:
*.(@node=='procedural') and (not /aiStandIn5/aiStandIn5Shape) and not (*/aiStandIn1/*)
With Debug-level verbosity, I can check what selections are "cooked" by the operator:
00:21:00  2241MB         |   [proc] /aiStandIn5/aiStandIn5Shape: loaded 5 nodes (5 objects, 0 shaders)
00:21:00  2241MB         |   [operators] init op: 'aiSetParameter1'
00:21:00  2241MB         |   [operators] cook op: 'aiSetParameter1' | node: '/aiStandIn5/aiStandIn5Shape/aiStandIn3/aiStandIn3Shape'
00:21:00  2241MB         |   [operators] cook op: 'aiSetParameter1' | node: '/aiStandIn5/aiStandIn5Shape/aiStandIn4/aiStandIn4Shape'
00:21:00  2241MB         |   [operators] cook op: 'aiSetParameter1' | node: '/aiStandIn5/aiStandIn5Shape/aiStandIn2/aiStandIn2Shape'
00:21:00  2241MB         |   [operators] cook op: 'aiSetParameter1' | node: '/aiStandIn5/aiStandIn5Shape/aiStandIn/aiStandInShape'
00:21:00  2241MB         |   [operators] cook op: 'aiSetParameter1' | node: '/aiStandIn5/aiStandIn5Shape/aiStandIn1/aiStandIn1Shape'
// Stephen Blair
// Arnold Renderer Support
n_rehberg
Hi Stephen,
thanks for the tips. I think I understand it now. I was hiding the underlying geo in the leaf standins too. The trick was to only include procedurals. This works for me now>
*.(@node=='procedural') and (not /aiStandIn1/aiStandIn1Shape)
Since my operator is connect to the standin I don't think I need to include the top level standin since the help states:
If an operator is being evaluated with regards to a procedural it's connected to the selection expression is assumed to be relative to the procedural's namespace (see operator graphs below).
Nico
