Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
How can I achieve a wet road effect in arnold 5?
4 REPLIES 4
OLADIPO_ADEBAYO
842 Views, 4 Replies
Tags (3)
Labels (3)
4 REPLIES 4
in reply to: OLADIPO_ADEBAYO
With a coat layer that you can drive with a noise/map. Low roughness, water IOR (1.33) and maybe a bump map.
OLADIPO_ADEBAYO
Hi, thanks I have tried this without much success. Can you please share a screenshot of arnold node texture of achieving this. Thanks
Check it out, thats the approach I would try.
Thats just a base, of course you need to polish the shading network and add some more stuff to get a convincing result: a nice asphalt texture, a good bump/normalmap, roughness map... and so on.
You can also use the "water map" to darken out the diffuse map (wet asphalt is usually darker than dry asphalt), mask out a secondary bumpmap for the coat bump (eg.).
Also lighting is a big factor when working with reflections like water. Use a good HDRI! Maybe thats why its not working for you?!
