Holes that randomly disappear with OSL
pproestos
pproestos
I don't know how to describe it...
I want to have an effect like this:
I mean i want the holes that randomly disappear from the top to the bottom...
I am using Mad's shape OSL shader and a gradient map, but of course
I cannot archive the effect I want...
Any help I appreciate a lot. thx.
**My solution that is...not a solution:
madsd
You want to utilize the simple tiles instead, that has ID.
Then let a ramp over v dictate probability to print a hole.
pproestos
not being able to do it... 🙂
madsd
One way of doing it.
Update: added 2020 file.
madsd
It can be improved to be fail safe from the curve, you need to handle the float values delecatly.
Implementing a step curve will fix this. Also known as posterize.
madsd
Like this, open gif full to inspect details.
Change the defaul Catmul rom interpolation to linear for point 0 and 1.
pproestos
@Mads... how many THANKS again... Every time I have a shader challenge to do, seems impossible till you answer... 🙂
I will try to understand the mecchanism later on... 🙂
