I have read that you cannot use a matte (holdout) object if you are rendering GPU. Not interested in shadows, just want a matte object. Has this been dealt with? Shocking, all I want is an object to basically render a black alpha.
Does anybody have a workaround that doesn't involve a second render pass just to get an alpha for my scene?
Solved by Stephen.Blair. Go to Solution.
That's right, matte (the matte parameter on a shape, the matte shader, and the matte parameters on a standard_surface) are not supported yet on GPU.
How about a custom AOV where you output black for some objects, and white for all the rest? That's doable. But if you have partial transparency, that's more complicated.
