Glass shader problem in Max 2020
sotomangel
sotomangel
Hello.
I'm having problem with glass shader in Max 2020 and start to find answer in this forum and I found this thread: https://answers.arnoldrenderer.com/questions/4890/view.html
I download the file that Mads fixed, save the material and load in my scene:
This glass shader I made with Mads settings, if you notice the cristal is black (I copied all presets).
This glass shader that Mads made shows different and mine is the same:
I don't now what is the problem, but I can't make a good glass shader in Max 2020, is there any problem with arnold updates?
If you download the Arnold Shaders from the help page:(https://docs.arnoldrenderer.com/display/A5AF3DSUG/Material+Library) and load in Max 2020, it has the same problem.
Could you help me?
Thanks.
File: https://drive.google.com/open?id=1-cSL_SxA9N9sGaXQF0OU3gm4K_jBy-g_
lee_griggs
Did you try this one?
Lee Griggs
Arnold rendering specialist
AUTODESK
sotomangel
Hello Griggs.
This link that you gave me was the material that I test, and the glass material always render with a tint.
I tried in maya with Arnold Material and the glass shows realistic but in Max the glass is not the same.
I have a question: Why in maya if I want to create a glass material in arnold, I only need to select the material and change the Base Weight to 0, specular 1 and transmission 1 and press render.?
As you can see in the image the cristal shows different (more realistic) but in Max I have to tweak to obtain the same result.
The material in arnold help page have a gray tint (always), if I create a glass material (always gray tint). Could you check that please?
lee_griggs
I've exported it from the MtoA library, so it should be exactly the same now. Can you try it and confirm it, please?
Lee Griggs
AUTODESK
sotomangel
Thanks Griggs.
I found a issue (or I supposed) with physical cam in Max, and I'll appreciate if you could help me.
If I use a physical cam to render glass (sphere) and the parameters with this cam is f=8, shutter 1/60, iso=100. Also I use skydome and use intensity and exposure=1.
The cristal is real.
But if I use a physical cam to render glass (sphere) and the parameters with this cam is f=8, shutter 1/100, or 1/250, 1/1000 and so on. Also I use skydome and use intensity=1 and exposure =8 (as default).
The rendering cristal appear black and I can't see trasmission.
Am I wrong?
Thanks.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
