Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Flickering of white paint objects during animation
7 REPLIES 7
Message 1 of 8
dacosdesign
619 Views, 7 Replies
On completion of an animation, the white deck of my ship object flickers and flashes when playing the AVI file.
7 REPLIES 7
Message 2 of 8
lee_griggs
in reply to: dacosdesign
Can you post some images? Does it use the Physical Sky?
Clamping
Fireflies
Tips for removing noise
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 8
dacosdesign
in reply to: lee_griggs
I'll sort images now. No, not Physical Sky. One Arnold Point light.
Message 4 of 8
dacosdesign
It might be difficult to see but from left to right the grey shadow on the deck should not be there. The grey shadow clears (centre image) as should be, and then back to displaying the extra grey shadow. In the animation this displays as 'flashing' on & off.
Message 5 of 8
dacosdesign
Do you know if the logarithmic exposure control is the best for a walkthrough of the ships deck & fly by of the complete ship?
Message 6 of 8
I use the physical camera exposure control. The light on deck is a bit to bright. Also the light intensity varies between frames. Try rendering frames and merging the together, instead of directly to a compression. There is something wrong with the reflection on the deck, overly bright light, material, ... Try uploading a sample scene max 2018 and I will have a look at it. 😉
Message 7 of 8
lee_griggs
Could it be coincidental geometry?
Lee Griggs
AUTODESK
Message 8 of 8
dacosdesign
Thank you Michiel,
Thank you for getting in touch.
I think I've sorted it. The problem seems to be the deck's geometry. The whole ship is a linked AutoCAD model. After deleting the deck (about 8 different surfaces) and replacing it, a test render has worked fine.
Just for information:
With the original geometry I rendered frame No.350 as a still image, this showed the deck as white.
When I moved to frame No. 353 the deck showed the large grey shadow.
Changing any settings made frames 350 & 353 react in the opposite way so, frame 350 showed the grey shadow & frame 353 shows a completely white deck. The changes I made were everything from a different camera/exposure control to changing any levels available in the material and main light etc.
Ultimately replacing the geometry had to be the only thing left.
I've turned down the lights as you suggested & I'll try the physical camera exposure control as soon as I can.
Thanks you again for your efforts.
Dave
