Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Error 1114 MAXtoA
2 REPLIES 2
3411 Views, 2 Replies
Error 1114 MAXtoA
The following files are not loading with Error Code 1114 when starting 3ds Max 2018:
ArnoldLight.dlo
ArnoldLightFilterModifier.dlm
ArnoldVolumeObject.dlo
ArnoldShadersLoader.gup
The following files load correctly as viewed in the Plug-in Manager:
ArnoldGeometryPropertiesModifer.dlm
ArnoldProceduralObject.dlo
ArnoldFluidUtilLoader.dlu
ArnoldMaterial.dlt
AssExport.dle
Running on 3ds Max 2018 Update 3 on Windows 10 x64 1709. The OS is a fresh install. I previously tried to run it on 1607 with the same results.
Hardware:
AMD Phenom II X6 1045T
16GB RAM
GTX 1060 6GB
Does anyone know why this is happening?
Tags (1)
Labels (1)
2 REPLIES 2
Stephen.Blair
Looks like that processor doesn't support SSE4.1, and that's a minimum requirement for Arnold.
http://www.cpu-world.com/CPUs/K10/AMD-Phenom%20II%20X6%201045T%20-%20HDT45TWFK6DGR.html
// Stephen Blair
// Arnold Renderer Support
in reply to: Stephen.Blair
That's the missing information I needed. I was trying to look for the minimum requirements for Arnold before posting. Thank you for the answer!
