Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Array modifier support for Arnold procedural
2 REPLIES 2
teamSP26J
720 Views, 2 Replies
I tried to apply array modifier to an Arnold procedural without succes. Would it be possible to make it work?
3ds Max's basic Array tool works, so this should too I guess.
2 REPLIES 2
gandhics
in reply to: teamSP26J
Well.. this is technically not possible because Array modifier is mesh/poly modifier. A modifier can only output mesh/poly/spline. To copy/distribute Arnold procedural, it has to be an object level scatter that support render time instancing like pflow. Pflow can do it.
Array tool can do it because it is object level copy.
teamSP26J
in reply to: gandhics
Thanks for the explanation, so my options are pflow, tyflow (maybe) and object instancing.
