Arnold Procedural loads but doesnt show or render
RenderQ
Message 1 of 14
RenderQ
Hi, when I load procedural file it shows in modifier panel but is empty in the viewport. Tried this with my own .ass as well as Arnold tutorial .ass file (soldier model). Using latest max24 and up to date MaxToA.
Replies (13)
Message 2 of 14
CiroCardoso3v
The Display Mode is set to Bounding Box. What does it happen when you change to display geometry?
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Message 3 of 14
lee_griggs
Yes, change the display mode as Ciro says. I have had something similar where it is so big that my camera is inside it or that it is off to the side of the camera view.
Are you using the latest plugin?
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 4 of 14
RenderQ
I am on the latest update, I exported teapot as an .ass file and loaded using procedural, set display as shape and still nothing. file is stored on my desktop
Message 5 of 14
CiroCardoso
Can you provide de file, for a quick test on my side?
Message 6 of 14
RenderQ
try anything, export teapot like me, I even tried with a tutorial scene from arnold docs
https://areadownloads.autodesk.com/wdm/arnold/maxtoa/Procedurals-soldiers.zip
Message 7 of 14
wernienst
Same problem here. See this:
(the soldier_stand.ass file from the Arnold Tutorials)
And finally I've found the reason: It's an old acquaintance: Windows Non-US Regional Settings!!
If you set it to English (US), it works fine!
I've sent a notice to Autodesk Feedback.
Message 8 of 14
wernienst
Even more strange: an .ass file I created 2 years ago works fine!
Message 9 of 14
CiroCardoso3v
That is weird.
On my side it seems to be working properly
Ciro Cardoso
Message 10 of 14
wernienst
Well, it's definitely a decimal character, not a language setting thing. If I set Regional to German (Switzerland), it works, if to German (Germany), it does not!
Message 11 of 14
CiroCardoso3v
That is weird. I am going to report this to the Devs.
Ciro Cardoso
Message 12 of 14
RenderQ
Thank you guys for looking into it
Message 13 of 14
MiquelRamos
EDIT: Solution found, was changing the units system in Windows to English (US).
Message 14 of 14
RenderQ
Thanks guys, I tried changing decimal character in windows from "," to "." and it now loads. I hope devs will catch this at some point.
