Hello, today I found a very strange, situation while setting up a quick test sceneon Max 2018, I was using the active shade to set up lights and materials, the light is an Arnold skylight, the materials are all physical materials, and a simple fluid simulation, while working in the active shade everything is working fine, I even rendered a quick animation of the sim with production, made some changes, and when rendering the sim again the production render produces black frames with out processing anything.
I merged the file into a new scene and is working fine. but I don´t know what caused the error itself or how to correct it.
Try to render without the fluid simulation if that helps.
When I tested the fluid simulation there where still some bugs.
Your answer came as I actually did that and effectively it works, in the log of the render it marks an error with the fluid simulation:
"[Arnold]: [BIFROST] Could not find object 'Foam' in path 'E:\Docs\01 Trabajo\Proyectos\2018\Conceptos creativos\Fotorealismo\SimCache\liquido 92\Liquid001\Solver01\/Foam' [Arnold]: [proc] max_Foam: error in user init from "
So I will look into the fluid settings to solve that in the actual simulation
thanks Michel!
