Dear Alias,
As a previous long time user of the software. I wanted to let you know that I appreciate your work and the software.
Although I am no longer a user of the software, I wanted to share a few humble suggestions that I felt during my time as a daily user.
- Select all visible objects with one hotkey. Visible as in 'not hidden', not 'viewable from the perspective view'
- Assign layers to hotkey. Example:
- If, layer A is assigned to F1.
When F1 is pressed, it would toggle visibility of layer A.
When F1 + shift(?) is pressed while there is a object selected, the object would be assigned to the layer.
- Instead of Control,shift,alt if it was S,D,F. It would be more comfortable for the user.
- While using the Marking Menu, if an additional button is pressed, it will select the 2nd(3rd,4th,...) in line (if the marking menu location has multiple commands lined up)
Thank you for taking your time to read this.
I hope it is helpful.
Thank you for the great software.
Have a nice day.
Best,
Roy Roh
