IDEA: Ability to quickly trim an overbuilt surface based on U/V similar to the detach tool.
Essentially the same as detach tool but instead of creating multiple pieces, it allows you to keep, discard, or divide.
Currently the workflow requires multiple tools and steps such as Duplicate curve(Interactive ON) to create a curve, then project normal and trim.
This feature would improve the workflow for over built surfaces or situation that you want to be aligned to the primary surface parameterization but need the ability to retain the original surf and theoretical intersection. keeping the overbuilt surface makes changes alot easier, sharing data across multiple users and gives engineering more flexibility for flange and b-side creation.
