Tool Locator with fuzzy logic
Hallo,
You guys updated the tool locator with Alias 2019.3. Actually the first time I noticed the tool.
But I instantly noticed: the tool would be much more useful if it also come with some better fuzzy-search-algorithm.
i.e. if I search a tool that helps to put surfaces on a mesh, typing the key-words "surface mesh" / "mesh surface" gives no result. Typing "surface" or "mesh" results in 30+ results, which is not too helpful.
Or I type exacly "surface from mesh". Which than doesnt find the tool Fit Scan; but this also could be helpful to put surfaces on a mesh.
So would be great if the Tool makes Suggestions based on the key-words, and related tools.
Similar algorithm with proper suggestions is already implied in Dynamo.
Even better, the search algorithm in Rhino/Grasshopper. It also handles spelling mistakes very well.
Regards
David
