The evolution of the marking menu
The problem:
I've been trying to keep my screen as clean as possible and I think the marker menu is too long now. Even on a large screen, the problem often arises that the lower part of the menu is outside the visible area...
The proposed solution:
My idea would be to add columns and the option of headings.
With 3 columns side by side you could have a clearer and navigation would be just as good as with just one in the middle. You can customize it by using in 1, 2 or 3 columns. The old allocation, as currently with only one column in the middle, would still be feasible. A total of 7 individual arrangement variants would be conceivable.
The optional headings provide a better overview and should stand out from the others due to their centered position in the box.
Thank you for your attention.
