In the evaluate tool set you find the tool "surface continuity". Under options you find "show max labels" My suggest: Please add the possibility to "show minimum labels" too. This would make it easy to check the minimum angle between two surfaces which meet in position. For example, you would like to check if a kink is at minimum 7°deg. Therefore a designer can make sure that a kink is visible in a milled model.
