Hi ,
Can u make the 'bridge tool' work between curves as well, my workflow is to use 1 deg curves (similar to maya's polygon curve) to construct my subd model,
My current workaround is to 'extrude edge' off the poly curve and then bridge between the edge loops.
Also if i could be able to bridge between 3 sets of curves, like the shift+skin tool, that would be great
Thanks in advance
