solution to use lsp with attributed blocks.
hi
i was using lisp file to write the area of  closed plines. i used a block with attribute. in acad 2007 it works properly ( it write the attribute value 'x' value and the 'y' value of the pline). but the same lsp file  in acad2014 it is asking for the attribute value. if you enter it writes default value is taking. looking for a solution.
