Keep settings in the option window
The tool settings always go back to some random state. Please make it remember the settings i last entered and keep them there until i change them.
5 Comments
bob55
If you save your Preferences via Menu->User Preferences->Save Preferences, the values for all the tools will be saved. Next time you run Alias those settings will be used.
flo_deluxe
Thanks for the comment, but i didnt meant to save the prefs everytime i change the settings for fillets i.e. The tool should remember everytime i change the settings without saving the prefs automatically.
bob55
It would be useful for us if you could give is a workflow using a particular tool where you expect the values to be saved but they are not.  You could do a video if that's easier.
http://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/ENU/123112/files/download-autod...
flo_deluxe
Hi... no need for a video... i open a tool, i.e. fillet... change the radius to 5... close the tool... next time i use the fillet tool, it should have remembered the settings i put in before... It even happens when i click NEXT in the tool window that the settings change to some random numbers.
bob55
I cannot reproduce that behavior at all.  A video would give us a better context on this.
