Improved Set Local Axis controller
In developing models, it is often necessary to adjust the local orientation or placement of a component of a model in relation to another component. The current Local Axis Control tool is for this purpose and it generally works well. However, there is no means to measure the adjustments beyond a visual guess. It would be extremely useful to be able to type in a value representing the desired amount of change from the original position. Perhaps in the case of angular (rotational) changes, a detent for standard increments -5, 10, 15 degrees, etc. would be intuitive and effective. Visually displaying text depicting angular or translational changes would also be very helpful.
Dan
Idee einsenden
