Double symmetry layer
Hey Alias Team !
Would be nice to be able to get a double, triple, symmetry on a single layer !
For exemple, symmetry ZX and in the same time YX.
cheers
6 Comments
Hi Arthur,
You can select the layer and change the symmetry plane, it's there in ( Layers >symmetry >Set plane).
maxy_13
Hello ;
I'd like to modify that suggestion so the symmetry tool would be available to layers folder as well, so we can add multiple levels of symmetry with different axis to the same object(s).
Layered double hydroxides are obtained by partial isomorphous substitution of divalent metal ions by trivalent metal ions in the structure of mineral brucite.
@Anonymous wrote:
Hey Alias Team !
cheers
The widely reported three-layer polytype of rhombohedral symmetry, designated as polytype 3R1, is actually a one-layer polytype of monoclinic symmetry (space group C2/m, a = 5.401 Å, b = 9.355 Å, c = 11.02 Å, β = 98.89°). This structure has a cation-ordered metal hydroxide layer defined by a supercell a = √3 × a0; b = 3 × a0 (a0 = cell parameter of the cation-disordered rhombohedral cell) Facetime on PC
tina.sabri4283
Observer
@Anonymous wrote:
Hey Alias Team !
For LiteBlue, symmetry ZX and in the same time YX.
cheers
Thank you for the help, This might help.
FredGASSON
Observer
Hi There ,  (long time no write on the Forum !!)
-would it be possible to set a symetry on a "Folder" ?
Then we can get simple layer symetry on the geometry, and by adding a level of folder or subfolder, we can add new levels of symetry.
Typical example is modeling driver "half seat" on a layer, then to watch the passanger seat.... until now, its a copy of the geometry. (no way to instance the symetry.)
