Diferent colour for WELDED/UNWELDED EDGES in SubD
It would be very useful to get a different colour when you weld edges in BOXMOD shading.
I.e. Two adjacent edges, unwelded, then, typical colour. The same adjacent edges, welded, different colour.
If you could customize the different colour, still better.
So, when you are using Boxmod, you easily are able to know which edges are welded and wich ones not.
6 Comments
Thanks for the information keep sharing such informative post keep suggesting such post.
BarryKimball
This info/display setting is already available, though not via a color attribute. Subdivision body display attributes are controlled by the Object Display->Draw Style. Unwelded edges would be boundary edges, those edges can be set to display thicker than regular edges or creased edges.
This is so interesting and informative!! Please let us know more. 5kW PV systems for home
A scientific cuboid cube is a three-dimensional solid object bounded by six square The cube is the only convex polyhedron whose faces are all squares. The cube has three uniform colorings, named by the colors of the square faces around each vertex: Each symmetry form has a different Wythoff symbol.
This collection presents different furniture which you might ... FABRICATION IDEAS #WELDING Welded Furniture, Iron Furniture, Steel ... The base is made from 40mm steel box section, professionally welded together and the corners blended. ... H: 43 cm / 16,9 iches The legs (frame) of the table can be in different colors.
mypremiercreditcard
