Diagnostic shader surface evaluation
Hi there,
I have an idea for the Diagnostic shader surface evaluation tool: instead of setting the drafting angles new for each project, or stage,it would be helpful to install customizable presets of various diagnostic shaders, where I can save settings such as drafting angle, drafting vector and so on. The benefit would be I simply click on the preset which has been saved previously and save time.
Kind regards
Tobias Rau
2 Comments
wayne.olive
Hello Tobias,
You can already drag/drop an instance (or multiple instances) of any diagnostic shader (including surface evaluation) to a shelf.  Once on the shelf you can customize each instance to any settings you desire.  Additionally (if you wish) you can also add those instances to your marking menu for fast access.
cheers,
Wayne
Hey Wayne,
thanks a lot for your help, it really works (of course it does 😄 )
i'll send that around in our company for everybody!
Cheers
Tobi
