Angular dev. table, Freeform blend con.,Intersect cur. ,Curve sec., Align opt.
Angular deviation table it will be nice when is posible to setup Show min. labels as it is in a icon.
Angular deviation table it make no sence to see angular graph for bouth surfaces it is mess , what about graph according that which one is selected first.
Freeform blend it will be nice to drag boundaries along the patch.
Intersect curve and detach tool is working 50% so Im using Curve section to trim.
Curve section it will be nice to put in curve section trim bouth (also will be nice to curves will automaticaly extend when there is a real intersection)
Aliagn options - You have a good idea with diagnostic feedback but it is working half way when i set G0 it will check only G0 but no tangency we normaly using it for a check of a angle in IS it is the fastest way anyway when I set up Specifi Chect Tangent there is no MIN.
