Add ability to hotkey custom theme colours
Hi, just a small request, would it be possible to add customized colour themes into the Preferences/Colour Themes section, as well as light/dark ( or make light /dark customizable ) so that they can be hot keyed for quick modification?
Brian
2 Comments
bob55
You can customize both the dark and light themes.  For example to change the dark theme first select it, then select menu->Preferences->Color Themes->Customize and change the colors you wish and from the Color Theme editor select File Export and name the file default_dark_colors.clrs or default_light_colors.clrs respectively and those saved colors will be your defaults.  If you want to go back to the original defaults, remove the files.
As for hot-keying color themes, we would need a compelling use case.
I'd like to be able to hotkey the background colour so that I can switch between a dark and bright background in diagnostic mode, but have everything else as is.
