undo problems with alias design 2015
Arcane5988
Message 1 of 10
Arcane5988
I don't understand, why u provide UNDO function in ALIAS DESIGN when it has no use,
in lot of tools undo tool is not working
for example
after aplying fillets,I am not able to undone this process.
after applying attach operat.ion undone is not working....???
is there any solution for this??
and sometimes even surface fillet tool is not working properly always showing error.
Replies (9)
Message 2 of 10
duaxiong
The Edit->Undo function does not work for everything.  There is no fix for this.
The Surface Fillet tool has its own undo in its control box.
Message 3 of 10
Arcane5988
dear no undo option is there in its control box
Regards:-
Anil Chauhan
Message 4 of 10
duaxiong
Message 5 of 10
Arcane5988
this option works only in the running tool,
what if the tool is finished and then I want to undo the process.
this option does not work there  🙂
Message 6 of 10
duaxiong
Query Edit
or
First Pick the Surface Fillet and then go to the Surface Fillet tool's option/control box.
Message 7 of 10
Arcane5988
now please have another look at this photo.
how is it possible to undo this one whereas undo all in not available??
Message 8 of 10
Arcane5988
Ohh; now I got it
thank you very much dear.
Message 9 of 10
Arcane5988
but I didn't get the answer to my previous question, that how can I apply fillet on a rectangle created by using rectangle tool direct.
Message 10 of 10
duaxiong
You can't undo separate Surface Fillet functions all at once.
The "ALL" in Undo All refers to the many different options you can choose from within that single Surface Fillet procedure.
If you have deleted the History of the Surface Fillet, the Undo function will no longer work.  You can just simply delete the Surface Fillet surface and Untrim the two base surfaces to get back to where you started.
