Unable to drag keypoints freely with mouse
Message 1 of 13
I am using Alias Autostudio 2016 and I am unable to move keypoints by selecting and dragging them freely with mouse. On the other hand I can still select them by clicking on them, which makes them turn bright green, and then typing the coordinates of the destination point. I can also select them and snap them to curves or points. In such cases, as soon as I attempted snap, I can release the Ctrl key and then I can move the keypoint freely. I suppose I should have been able to move the keypoint freely in the first place, without first attempting the snap and then releasing the snap to keep moving the keypoint.
So to summarise, a keypoint refuses to move freely with mouse without first snapping to a curve or a point! Is this how it should be? I am also unable to move the centre of a keypoint circle by dragging in any way, other than just moving the whole circle the normal way. I wonder what is wrong.
Replies (12)
Message 2 of 13
Hello there,
The last command on the Keypoint curve tools is DRAG.
Using this tool you will be able to drag and drop keypoints freely.
Please mark as solution if it solved the problem. Kudos are appreciated
Message 3 of 13
bart4BD6T
Observer
Observer
2019 works for me but 2020 does not.
Bart Brejcha
Design-engine.com
Message 4 of 13
bob55
ou have to be in an ortho graphic view (Front, Back, etc) to move them freely.
Message 5 of 13
bart4BD6T
Observer
Observer
Thanks but no.    Tried that 😉
Bart Brejcha
Design-engine.com
Message 6 of 13
bob55
I've tried cut-of -the-day and 2016, and 2020RTM and "Drag Keypoint works fine.  Could you make a screen cast.  Perhaps I'm misunderstanding.   You can get the software here...
https://knowledge.autodesk.com/community/screencast
Message 7 of 13
shinji-pons
In order for Drag keypoints to work, you have to be in one of the "true" dedicated orthographic views. You will find those under the "Layouts" menu bar.
Using the Perspective view with Ortho faces will not work.
Message 8 of 13
Ranko_Design
Yes he is right, me too can not drag points of an elipse!!!!
I switch to top view with F5, and when I click on drag keypoints tool, points on elipse are not moving freely, but just in small increments, like its having a magnet snap to them,,,
so what is the problem...
its on alias studio 2020.3
thnks
Message 9 of 13
shinji-pons
It's possible that you have "snap to grid" turned on. Check the top right corner of your viewport to see if you have it on. You should see three icons with magnets (one for each type of snapping) that you can click on.
Message 10 of 13
Ranko_Design
No, they are off.
Strange that with circle I can move freely points, with rectangle too, line, arc...everything works fine, but elipse no!!!!
Nothing,,,With elipse It wont move them, if I click on one point on elipse it moves very little, so I have to click several times in a row to move it in small increments, as if something is not aloowing a point to move....
Its really strange...
Message 11 of 13
Michael-GG
Thanks for reporting. We can reproduce the behavior, it's a regression since Alias 2020 (worked fine in 2019.4). We have logged ALS-10108 for this, and will fix this as soon as possible.
GG
Michael G.-G.
Manager Quality Assurance Automotive
Message 12 of 13
Ranko_Design
It'll be any hotfix or .update? 2020.4 maybe?
thnks
Message 13 of 13
Michael-GG
Unfortunately, due to legal implications, I'm not allowed to make any statement on that until the software is officially released, sorry.
Michael G.-G.
