Surface Skin issues
Surface Skin issues
jojabw
Surface Skin issues
jojabw
Hello all,
I have a couple of questions regarding skin and skin 2012. I'm running Alias design 2018 and just installed this on an Imac pro. I was using 2016 on my previous Macbook pro where the skin tool worked fine. However in 2018 there are 2 issues that I can't get to the bottom of however much literature searching I do:
- The first is that there seems to be no Skin 2012 tool available. IS this because I'm running Design and not Autostudio?
- The second is that there seems to be no explicit control in the Skin tool. IS this also because of the version I'm using?
Any help is great appreciated as I've been modelling with the Skin tool since 1994 and suddenly I have no access to span creation that I had for the last 24 years!
James
duaxiong
Skin 2012 was removed in Alias 2017.
I am running Alias Surface 2018.5, and I have Explicit Control in my Skin tool.
AliasJB
As Dua pointed out, Skin 2012 has been removed.
Alias Design doesn't have Explicit Control.  2012 only allowed you to specify V spans though, right?
jojabw
Hey guys,
thanks for the quick feedback and update on the functionality!
The great thing I found about 2012 was to quickly get U/V CVs spread across the surface between generating curves. This was a core tool for quick conceptualisating (I'm a product designer with 25+ years experience, 23 of those on Alias) and I cannot fathom why this has been removed from Design when it has been there since I first used Alias in '95. Can I ask what the rationale is to remove explicit control and 2012?
Thanks again and kr's from Amsterdam!
James
