SKIN TOOL - CONTINUITY CHECK ***BUG***
Hey Guys,
I have a problem with the Skin tool since 2020.3 update (Now using 2021). Even though i turn off "Continuity Check" and save the settings, every time i use skin, it enables itself. Very annoyed by it. Do you guys know why? Or how can i fix it?
I was hoping they will fix it for 2021, but still the same issue...
KaiTi.L
Hi Samir,
is the issue still existing?
If yes are you able to share your pref set?
How do you execute the skin tool?
Do use the one from the palette or are you starting the skin tool from a shelf?
I tested the described behaviour in different Alias versions and was not able to reproduce the issue.
What can cause the described behaviour: If you are starting the skin tool from the what is new shelf you are not able to overwrite the settings. The what is new shelf is reset after each start of Alias.
If this is the case, I would recommend to create a new custom shelf and save this one.
Let me know if this solves your request.
Best regards
Kai-Timo
