Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Should small objects be modeled in real world scale? What tolerances to use?
If I'm modeling a small object, like a phone or a computer, should I use real world scale or should I model for example at 1:10 scale? And what construction options should I use?
Right now I'm doing it in real scale (1:1) and using CATIA V5 preset where maximum gap is 0.001 mm. But I'm geting visible gaps when I'm rendering in Keyshot, even using NURBS mode I get visible gap, although barely visible. I guess I could photoshop it out, but that's not very desirable approach, and if I need to do an animation that's just out of the question. And I don't wanna render in NURBS mode just to get acceptable results anyway because it takes too long.
I uploaded a couple of images (part of the render where a gap is visible), one is normal size and another is same image enlarged so you can see it better.
Could you share the file ? And did you check the continuity in between the surfaces ? Since you said that there is a gap there, how do you patch it ?
Turns out there was an actual gap and probably not a tolerance issue. I still have another problem with a model so maybe I will create another post and delete this one.
