Is there a way to scale an object to exact dimensions?
I can't figure out a way to scale an object to the exact dimension. I'm attaching a screenshot. I want this rounded object (inside the ractangle) to touch top and bottom of the rectangle, so it's would be 4 mm height.
I read that these kinds of operations are difficult or even impossible to achieve automatically in Alias, is that true?
Hi mumblefluff,
It is possible to achieve this precisely in Alias. They are not that difficult or even impossible... Please take a look at this video.
http://sendvid.com/3prnu80i
Well that's why I said  "automatically", making dimensions (with distance tool) and scaling manually is not exactly automatic. I tried your method in the video, I never used transform CV tool before so I was curious. But what I found is that it transforms every curve separately, even if my object is grouped, so it doesn't work for me (because my object is actually from 8 curves and not aligned). I assume it worked for you because there was alignment history active.
I noticed there is mouse sensitivity setting in transform CV tool, is that why you used it instead of simple scale/nonProportional scale? Because I don't see any other reasons why would you need transform CV tool.
So just to get this straight, as I understand, using distance tool and just resizing objects manually (while zoomed in a lot to make it easy to get exact number) is the standard way of resizing to exact dimensions? If yes, it's ok, I just wanted to make sure I'm not missing some obvious automatic method every time 🙂
