Revolves using vectors look triangular
Message 1 of 9
One of my revolves appear fine (on second try) and the rest appear triangular:
Actually, I see now that even the one I thought was fine, looks triangular when unshaded.
Anyone know what's wrong? Never used vectors before, but I believe I need it in this case.
Replies (8)
Message 2 of 9
Just found out that intersecting the revolve with another surface generates proper cos, but it crashes Alias on trim...
Message 3 of 9
It's bad form to tack on a question, perhaps, but I did the revolve a different way (still using a vector), and stitch is now behaving in a way I've never seen before:
How is it possible that's it's not following the original surface (the blue line)? I killed all construction history before stitching...
Message 4 of 9
michael_wu
eobet, thanks for reporting this bug. I can easily reproduce the triangluar look issue. Can you give more description of the crash? Thank you!
Message 5 of 9
After selecting the revolve with the triangular look, use the intersect tool to produce cos on both surfaces of an intersecting surface and then attempt a trim on either surface.
I'm using Alias Design 2015 SP2.
Below you can find an example of the similar revolve stiching problem I posted about above, after I managed a work around to avoid the triangular look:
(Solidworks managed to stitch the surfaces without issue.)
Message 6 of 9
michael_wu
Ok, I can reproduce it now.
Message 7 of 9
Thanks!
Did you see the edit I made while you were posting about the stitching issue?
Message 8 of 9
michael_wu
Yes, I can see it. I have reported two bugs about the issue. Thanks for your reporting.
Message 9 of 9
michael_wu
Just a walk around: If you snap the end CVs of the revolve surface, the artifect on the surface will be gone. You can refer the attached video.
