Problem with filletting
battiloroandrea5
battiloroandrea5
Community Visitor
Community Visitor
I have to do an heavy work , because i have to fillet many corners. The problem is that Alias doen't trim the chosen surfaces when i execute the srfillet command. Can anybody help me with son tips and tricks?
Turn off "trim" when building the fillets and then hide the fillets and take a good close look at the COS's on the surfaces you want trimmed. You'll see gaps in the COS's or that they don't go all the way to the surface edges. This means there are gaps in the fillet surfaces (or they don't extend far enough at the ends) as they are created. To get it all fixed is a process with multiple solutions, BUT I would suggest starting by making sure all your original surfaces have tight positional and tangency accuracy to each other so you know that's not a problem going forward. Set all your modeling tolerances tight (you won't regret it). COS tolerance setting should be tight so that a fillet boundary edge creates an accurate and equivalent trim COS. THEN investigate the COS gaps and close the gaps or bridge them.
I simply used fillet on that edge (actually on all edges) but the surface produced by fillet is not good. how to fix this issue?
Thanks in advance.
I am also encountering this issue. Dont know why its hapenning AARP Medicare
