Object has ungrouped incorrectly
Message 1 of 10
Hey. Question about Alias Surface 2021. Perhaps this is a bug and was made on purpose - but not very convenient! On previous versions of the program (2019), when there are several subgroups within one group - when you press ungroup, the program showed the updated group without the detached part. Why, in the new version, when you press ungroup - all the parts continue to glow as if they were grouped. When pressed again, no ungrouping occurs at all!
Replies (9)
Message 2 of 10
How it was working correctly on Alias Surface 2019.
Message 3 of 10
bob55
I don't see that behavior in 2019.  What are you options for ungroup set to.
Message 4 of 10
On previous versions it was working as in 2019 version.
Message 5 of 10
Above, I showed a screenshot from Alias 2019 - Ungroup was working. And this is the logical behavior of the program - if you ungroup a large group to a small one, then the details in the group become less. Why can I see this in my screenshot - but you don't?
Message 6 of 10
bob55
This is what I see in Surface 2019.4
Message 7 of 10
Yes, but this is not logical - it should be like this: if you separate an element from the general group, it fade out and the number of parts in the group becomes less. Alias 2011 - 2019 worked like that. It still works for me. I checked it on another computer - it also works correctly there. Try to press ungroup twice.
Message 8 of 10
KaiTi.L
@Anonymous
The ungroup issue in Alias 2021.2 is valid and known as ALS-11743.
We are working on a fix.
Message 9 of 10
Thank you very much for your understanding.
Message 10 of 10
KaiTi.L
