I can't believe these are still issues...
mcgeecardesign
mcgeecardesign
There are a few things that I'm finding that I really am baffled that they're still an issue in 2020, and should be looked into. Let's see if you agree!
1. Trimming a surface should NOT affect aligned surfaces to any of its CoS. I'm sick of trimming and finding an attached fillet siphoning down to my new trim edge. I swear this wasn't the case in the past. This is a simple thing that has me infuriated on daily basis.
2. Why does undo still suck??? Undo should work for anything that does not have history...that simple. Why can't I undo the extension of a surface? Why is the undo history so fragile when moving or deleting objects? Use one menu or tool and undo is GONE. I get that having history makes certain aspects of an undo system complicated. But come on.
Just a couple things I'm fed up with as someone in the industry that uses this 8 hours a day. Anybody noticing these things? I wish they would be fixed! Forget new features, forget SubD (it's cool), get the simple stuff right first!!
One final idea for future versions if it's possible?
Find a way to be able to immediately kill a tool with "esc" when it's clearly overloaded, like when you align to the wrong surface, or have a fillet edge-align way too far on one side. Or when you hit CHECK MODEL accidentally!!!!
systembolaget
The lack of a proper undo like in Rhino is a big mystery and since long one of the major deterrants for novices, apart from other issues, like not being able to simply type in the name of a tool to be used or the object lister not even having a new layer menu item. Perplexing. Things like no proper undo infuriate even the experienced user.
Intuos5
Apparently Icem users are complaining about the same undo issues in their package as well.
Type a product name
