How to np scale several surface in same direction?
I want to scale the top row of CVs to the green line. I made a special construction plane for this, and I'm using non-proportional scale.
The trouble is, all but one surface scale in the expected direction. The other surface scales in the reverse direction.
I've zeroed out transforms and the orientation is the same on the relevant surfaces, yet this doesn't help.
I can see that the U and V symbols are in the opposite corners on one surface, but how to I swap this?
File is attached.
Oh, ****, it was a stray pivot. I can even see it in the image.
And you can't delete topics here anymore.
