Dynamo - Build curves from point lists
danielcUPK8E
danielcUPK8E
Hi, I'm a fairly new user of Dynamo for Alias and I'm trying to build NURBS curves that run through a list of points on section curves. The list of points, from each of the section curves, is combined into a single list and I'm then using 'GetItemFromIndex' to grab the first point from each list sublevel to create the NURBS curve. Does anyone know how I can create all the NURBS curves at once by 'Getting' the 2nd point of each list, followed by the 3rd, and the fourth and so on?
c3systems
Hi Daniel,
I think your solution seems too complicated..
Couple of points..
1, Don't know why you need multiple "From Alias" nodes. You can import all the curves at once as a "List"
2, The trick is to "transpose" the matrix or Lists.
It might be difficult to understand Lists if you are not familiar with Matrix. Please do take a look at https://www.mathsisfun.com/algebra/matrix-introduction.html
Hope it helps.
Hope it helps.
danielcUPK8E
Thanks! That really helps.
danielcUPK8E
Hi again,
I was hoping you could help me a little further along. I want to build a NURBS curve from the 'nth' point of each list i.e. join point 1 from each curve, join point 2 from each curve etc (as I have done for the first curve shown in my image). I also deliberately did not transpose the lists so I could 'ShiftIndices' of each point set by different amounts on each curve (maybe there is a simpler way to do this).
Thanks again for your time!
