Still, it has not been fixed when you go to edit > duplicate object options box...when you hit 'reset' nothing changes. All other versions prior to 2015 would reset the choices to default. I thought the first update fixed this, but still not working. Has any one else noticed this?
Hi donest,
Is this the duplicate tool that you are talking about ? Please refer to the below screenshot. I have no problem in resetting the duplicate settings to the default one.
Hi donest,
Yes! That's the one! I wonder what's wrong on my end. The video card is a quadro K4000. I have a pretty good workstation. I don't get it. I still have 2014 installed and that works fine. I'm using the recommended driver as well.
Well, why not you try to perform a complete uninstall of your current Alias 2015, restart your PC and then reinstall it. Restart again and try it out. Please export your user preference for Alias before this.
I uninstalled 2015 and reinstalled it. I noticed that my prefs were already there without the program asking me if I wanted to import from a previous version. So, when attempting to reset the duplicate object, same thing happened. So I uninstalled, then I deleted the prefs from the 2015 folder (in fact, I deleted that whole folder). I downloaded and installed 2016 today, and the same thing is happening.
Install the latest service pack.. http://knowledge.autodesk.com/support/alias-products/downloads/caas/downloads/content/alias-2015-ser...
If this still can't solve your problem then,
Create a new admin account, use it to uninstall your existing Alias installation. then reinstall at the same new admin account. See if this helps!
Hello-
I am not having any issues with the reset in 2015.
Can you please record a screencast video showing me what is happening exactly? Screencast.
Please also send me a system information file. System information file.
I will send the same response to your new case number 10623422.
Thank you.
Jonathan Matthews
Autodesk Technical Support.
Hello-
Thank you.
Jonathan Matthews
Sys Info and Screencast uploaded
I was jumping the gun! Now, the reset button, when clicked on, will give me some values that I typed in shortly after setting up 2016. Always the same values...5 copies rotated around the Z axis 60 degrees. If I manually remove these settings and change them to some other values, clicking on the reset button changes everything back to 5 copies rotated 60 degrees around the Z axis.
Update...I have found that when exiting the program, it seems to save any settings in the Duplicate Object function so that the next time I start the program the settings are the same as when I left (naturally), but during use in that session, any time I hit "reset" all the settings return to where I left them the last time i shut the program down. In the past, anytime I hit "Reset" all settings were returned to default. So to correct what is happening now, just before exiting the program I set all the settings in Duplicate Object to their original default, save my preferences, and then whenever I use the program and hit "Reset", it goes back to default instead of where I last used them. Can someone check to see if that is what happens to them? Thx.
