Curve Offset> Attach broken?
dangertaz1
dangertaz1
I have a series of curves that are connected to each other.  I use Curve Offset on them with Attach checked on.  The curves offset correctly but they remain separate.
Is there a trick to having the offset curves attach together? I've tried the four different modes as well as toggling other Offset controls on and off.
BarryKimball
I cannot follow the setup. "I have a series of curves that are connected to each other." What does connected to each other" Is it 1 curve or multiple curves?
dangertaz1
Hopefully this screenshot clears it up.  It looks like the Blend and Attach options will work on all curves that are offset outward, but not inward.
BarryKimball
What version are you using?
dangertaz1
