Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Creating a solid .iges or .step model from an Alias Model
1 REPLY 1
797 Views, 1 Reply
Hey,
I'm currently trying to export an Alias model as either a solid .iges or .step file for milling.
The Alias model is currently hollow with just surfaces - however I need a solid finished model - does anyone know how to achieve this? I've tried exporting as .iges or .step but the model stays hollow.
I've used 'Meshmixer' to create a solid model but this programme can only export in .stl or .obj (Not what i want)
Thanks for you help!
Hey,
1 REPLY 1
You have to stitch the model. Just like in any other software. If you work with surfaces - you need to knit/join/stitch them.
So:
1. Stitch
2. Pick Shell
3. Export active as... > stp
Regardless of that - some software (e.g. Solidworks) does that automatically.
You should also take into consideration - .iges is just surfaces. The translation into solid is done by the software youre importing into.
Concentrate on .stp.
So:
1. Stitch
2. Pick Shell
