Hi everyone, after carrying out the weld command between two edges, the layer loses symmetry and the model no longer reacts to any shade. The program crashes, the file becomes corrupted and lost, and the emergency save file (msaved) is empty. I absolutely need to restore my file, what can I do? Thanks everyone in advance.
Hi, did you have 'Checkpoints' turned on? You might be able to retrieve one of them if you did. If not then I think you need to restore from a previous save or backup.
Cheers
Dan
Are you using 2024? Did you notice that they moved the Msaved folder to Autodesk/Alias/Msaved? It is no longer saved under wire/msaved.
