Could not run my Alias
chh27
Observer Observer
chh27
Observer
Observer
I could not  launch my Alias 2016
I looked up similar  Q&A
lin
https://forums.autodesk.com/t5/installation-licensing/alias-quot-you-do-not-have-a-user-data-directo...
But, it didn't work anyway.
I re-installed again, but still. However, other AutoDesk products can run such as "Automotive Assets 2016".
Also, I found it build a folder on " One Drive", install of locating the path on my C driveCapture2.PNG
Is this to do anything with my problem?
My OS is Win 10
カワダチアキ
Autodesk Support
Autodesk Support
Dear @chh27
You are using Chinese for some folders, right? If so please confirm you are NOT use any Chinese characters on your my document path to C:\Users\[username]\My Documents
It means you can not use Chinese character for your Windows login name to use Alias.
Above can not solve the issue, please try below:
  1. Please create a folder only with single-byte characters on your local PC. (i.e "C:\User\alias")
  2. Please set the folder to Alias folder by setting environment value as ALIAS_WORKENV = C:\User\alias
