Circle from three lines
Message 1 of 16
Can i build a circle out of 3 lines.
Replies (15)
Message 2 of 16
AliasJB
If you mean out of 3 curves, yes you can.
In the Circle options, turn OFF periodic, and you can specify the number of segments, the degree and spans.
3 curve circle3 curve circleCircle optionsCircle options
Message 3 of 16
Hi
Thank you for the effort.
I wanted to build a Circle which is Tangent to 3 Lines. These lines are in a single Plane. The simplest example would be 3 sides of a square.
Best Regards
Sadat
Message 4 of 16
systembolaget
Use AutoCAD for such kind of 2D drafting tasks, then do the 3D model in Alias.
Message 5 of 16
Thank you for a replying which is kind of tangent to my query.
And if I have to use AutoCAD for these small things then the whole set of tools in Alias where we have 3 point curve, tangent to curve, perpendicular to curve are just drafting tools which are not supposed to be in Alias. Please raise a ticket to remove those.
The situation is not in 2 dimensions as you are thinking. For the sake of simplicity I explained it in 2D.
When I have 3 surfaces which are like the 3 sides of a cube and I want a fillet which is tangent to all surfaces I have to build a curve and then the surface as Alias is not having any command where i can build it directly by selecting the surfaces.
Thank you.
Message 6 of 16
systembolaget
Attach a file so it's possible to understand what you really mean.
The few very basic 2D tools in Alias are certainly not made for drafting. I have never seen anyone outputting an ISO/DIN compliant drawing.
Message 7 of 16
Hi
I can only attach a sketch of my problem.
If I am unable to clarify the situation then we have to wait till Monday.
Thank you in Advance
Happy Easter
Best Wishes.
Message 8 of 16
AliasJB
I suppose in your situation you could use Curves > Keypoint Curves > 3 Point Arc
3 point arc3 point arc
Message 9 of 16
AliasJB
"And if I have to use AutoCAD for these small things then the whole set of tools in Alias where we have 3 point curve, tangent to curve, perpendicular to curve are just drafting tools which are not supposed to be in Alias. Please raise a ticket to remove those."
Now I see that's exactly what you don't want.  If your attached surfaces are flat (as they appear to be in the sketch), I think you'll have to hand build it.  I don't believe there's an automatic way to do this.
Message 10 of 16
systembolaget
If the lines form a square, there is exactly one circle that fits, for each circle can be inscribed into a square; use a circle of the diameter that matches the square's height/width.
If the lines don't form a square, one can solve the algebraic equations or construct it "manually". Draw two lines that bi-sect the angle between two pairs of lines. Where these intersect is the centre of your circle. The radius of the circle is obtained by dropping a perpendicular line from the bisector intersection point as shown.
Greetings from the Easter bunny!
Message 11 of 16
Hi
3pt curve does not give me the exact Position where it is Tangent.
Message 12 of 16
Hi
In context 1 it is easy to get Tangent passing through all the sides.
But in Context 2 i cannot do it easily.
Any ways i did it by using ICEM where it can build a circle when we select 3 lines.
Thank You
Message 13 of 16
Here i took help from ICEM colleagues to create curves and then imported into Alias.
Thank you
Message 14 of 16
duaxiong
Yes...sadly, this is something that Alias has not ever been able to do.  It's frustrating when you have a target size that you HAVE to hit.  You end up having to put a point on that line...a point you don't necessarily want.
Message 15 of 16
systembolaget
Well, you don't have to do anything other than I described to make a circle tangent to three lines in a plane. It's actually very simple. Even in Alias ; )
Message 16 of 16
Hi
Yes the Suggestion you have is good.
For a given Situation of 3 lines nomatter whether it is a part of a cube or Rhombus or trapezoidal, we are gonna have one circle of certain constant radius Fitting in that Corner for each Situation.
So i suggest Alias can have a single command to achieve this.
The method suggested by Systembolaget, to do bit of construction in 2d is possible.
Thank You
