Hi!
I can't seem to change the rounds on my edges. I click on the edge, and when I enter the round it doesn't change. It has worked before, and on the same object. I had around 4 edges left to trim and then it got stuck on 1 and then changed to 3,899 or something. It's the battery lid I want to trim, and I tried restarting the program and the computer, even opening another file. A few times this worked, but most of the time it's like the program doesn't even react to what I enter. I want a pretty low number, because 1-3 doesn't work on all edges.
What am I doing wrong?
Thanks in advance,
Kate
Hi Kate,
Any chance you could share the battery lid file? Also, which version of Alias are you using?
Joe
Hi Joe!
I couldn't upload the wire-file, so I sent an image. I'm using alias 2018. Here's a zip 🙂
Kate
Hi Kate,
Thanks for sharing. I have asked one of our QA team members to look at this issue and see if he can help. Stay tuned!
Joe
Hi katerina, I have checked that the width of the extrude surface on the Batterilock is only 0.3mm. That's why the radius of fillet surface larger than 0.3 doesnot work between the two surfaces. If you decrease the radius, you should get the expected output. Please refer the images below.
