- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey there,
I’ve been desperately looking for an answer for the ever lasting question of “can I still BUY a Mac after the introduction of Apple’s M1 and STILL use Alias”.
Last week, I finally got my hands on my friend’s 2021 MacBook Pro (M1 Pro).
Within 15-20 min I had installed Parallels (Virtual Machine) which automatically installed Win 11 ARM as well.
Windows worked very well and therefore, the installation of Alias wasn’t a problem either.
I launched Alias and everything was how it’s supposed to be. I then opened a file and could perfectly use the view keys and tools, as well as the different shading modes. I also projected a few curves on the surfaces and built a few SUBDs cubes.
Everything was working fine and I was minutes away from buying a MacBook on the Apple website…
Problem 1)
Until I tried using the “marking menu” of the left mouse button because the menu simply wouldn’t open.
Instead, it seamed as the selection rectangle was activated by this key combination.
I connected another mouse and another keyboard to see if those were the source of the problem - but no luck with that either.
Every other marking menu worked fine except from the most important one for me.
Problem 2)
I thought I’d might be able to find a workaround for this first problem by changing the shortcuts for the marking menus and thereby still be able to get to use the M1 Pro’s power, but that was only until I discovered the second problem:
I wanted to save the project but when I clicked on “Save”, “Save as”, “rapid prototype” or any other kind of saving/export option nothing happened. The icon on the upper left corner flashed real quick every time I clicked on one of the mentioned above options.
Also, importing a User Preference Set wasn’t working either.
Then, I updated 2022.1 to 2022.2 and also tried the 2021 version of Alias but ended up with the same problem.
@AnonymousTeam
I know there is no real support for MacOS anymore and that running Windows on a Virtual Machine can cause problems.
But because the VM + Win worked so well and Windows 11 ARM perfectly emulated the X64 architecture that Alias needs, I can’t believe that this is a MacOS but rather an ARM-processor problem in general.
Assuming that ARM processor are the future of CPUs, I think this might be worth looking into for you.
Thanks in advance and stay safe
Malte Wohlfahrt
