Alias locks up MacPro MacOS 10.11.6 when loading workspace
cekuhnen
Mentor Mentor
Message 1 of 33
cekuhnen
when I select one of those icons
Alias 2016 or also 2017 locks up the computer.
Alias worked some weeks ago fine - now it does not anymore.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Replies (32)
Message 2 of 33
I have the exact same problem except I don't have those icons come up.. both 2016 and 2017 stopped working.  I tried to delete my preference files but still no luck. Freezes the whole computer.
Message 3 of 33
cekuhnen, do you happen to have a Nvidia graphics card?  For me if I switch to the OS X default graphic driver, Alias will load but the performance is crap.  Guessing Alias isn't happy with the latest Nvidia drivers?  Were you able to fix this?  Think I'm going to try to revert back to Yosemite if not.
Message 4 of 33
cekuhnen
@Anonymous Yes two GTX 970
seems to run fine with win10.
i am quite dissapointed that no one from AD responded here yet.
Claas Kuhnen
Message 5 of 33
mikeydwilly
Same problem! El Captain?
Message 6 of 33
Bummer.. I've been in contact with Alias tech support and they suspect it's a problem with the latest nvidia drivers.  Other thing it could be is that I have a flashed GTX980 to run on Mac and I suspect cekuhnen has flashed cards as well?  Maybe that has something to do with that?  I still have the ATI card that came with the computer.  I might try to put that back in and see if it will run alias..
Message 7 of 33
cekuhnen
@Anonymous@mikeydwilly
I have standard GTX 970s no flashed versions. Alias worked fine till some days ago !!!
I am now really upset that from AD no engineer looks into this thread.
I guess we better really just focus onto Fusion 360 where the forum is very responsive with
addressing user issues.
Claas Kuhnen
Message 8 of 33
mikeydwilly
Makes sense, I've just installed the latest nvidia, i had an earlier version running before, so ill switch it back and see how it goes.
Thank guys for info, will post to let you guys know
Message 9 of 33
Florian.Coenen
HI @cekuhnen
Have you already tried to reset the preferences of Alias by renaming the UserPrefs2017 and UserPrefs2016 folder?
I am wondering what has changed on your system since Alias cannot run anymore.
Have you installed any system tools, drivers or so on?
Best Regards,
Florian Coenen
Message 10 of 33
cekuhnen
@Florian.Coenen
Do you know where this folder is?
I removed everything I found when I installed Alias 2017 incl. everything in the Application Support folder in Library I found.
Claas Kuhnen
Message 11 of 33
Florian.Coenen
Hello @cekuhnen
The folder can be found here:
Mac: finder> library> preferences> autodesk> alias>
PC: C:\Users\%username%\AppData\Roaming\Autodesk\Alias
Here is also an article about that:
Reset user-specific settings in Autodesk Alias
I hope that is helpful.
Florian Coenen
Message 12 of 33
cekuhnen
@Florian.Coenen
Even with those removed the Mac completely freezes or at least the screen does.
I have hard restart.
Claas Kuhnen
Message 13 of 33
mikeydwilly
So i actually deleted the 2016 preferences, everything seems to be running ok now 🙂 Will post if otherwise
Message 14 of 33
Florian.Coenen
Hello @cekuhnen
you ,mentioned that Alias was running fine some weeks ago.
Do you know what has changed in the meantime.
I assume that something within your system has changed. Drivers, software, permissions, Firewall settings.
When the monitor is freezing, how long have you waited till you restarted the machine?
Could it be that the machine is unfreezing after a long time?
(The issue really feels like you have some graphic card issue or graphic driver issue.)
Best Regards,
Florian Coenen
Message 15 of 33
cekuhnen
@Florian.Coenen there was no updates done to the OS or Nvidia.
Claas Kuhnen
Message 16 of 33
Florian.Coenen
Hello @cekuhnen
The question is more what has changed in the meantime.
Maybe have a look into the logs of your system what has installed or updated in the meantime.
Potentially another software is interfering with Alias?
Have you tried to reinstall it?
Awaiting your reply.
Best  Regards,
Florian Coenen
Message 17 of 33
cekuhnen
@Florian.Coenen
Yes I uninstalled and reinstalled it. Normally Alias is one of the most rock solid applications.
The only thing I could maybe guess is that screen sharing apps are conflicting with it.
I installed Duet and AstroPad. But it would be odd in case Alias has issues with those as
everything else performs fine.
Let me check.
Claas Kuhnen
Claas Kuhnen
Message 18 of 33
Florian.Coenen
I have seen an internet explorer plugin causing Alias to CER-crash right after the start. Therefore I can imaging that any kind of updated or installed software can cause issues.
You are right, normally Alias is really solid.
Can you potentially go back in history using the Apple time machine?
Florian Coenen
Message 19 of 33
cekuhnen
@Florian.Coenen
I do not use Timemashine but I will try not uninstalling my screen sharing apps.
They are small - so no problem.
Give me 15 min
Claas Kuhnen
Claas Kuhnen
Message 20 of 33
cekuhnen
@Florian.Coenen
I removed the new apps
restarted
launched Alias
but it still freezes when initializing workflows.
here is a screencast:
https://goo.gl/photos/AMTRSsTGbMa9QaJY6
Claas Kuhnen
Claas Kuhnen
