Alias fails to open IGES files from One-Drive
wild-hunt
wild-hunt
Hi folks,
Alias fails when trying to open IGES files from One-Drive, while it works fine when opening the same file locally:
Pretty annoying, when you work with two computers. 😕
Cheers,
GG
PS: The forum does not support to attach IGES files. If you should not be able to reproduce this, I can send the file via email, but the problem is not file specific.
c3systems
Hi GG,
Not able to reproduce this error.. using 2025.1. Although the file size was only 256 KB.
Does it also happens with small files.
rauscht
Hi GG,
the reason for this surprising behavior seems to be the German Umlaut "ä" contained in your original file path.
Please try the following:
  • Copy the original file from One-Drive folder having that Umlaut into a different folder on One-Drive which doesn't have a special character (no Umlauts, Accents etc.)
  • Repeat the IGS import from that new One-Drive folder
    Expectation: this time the data comes in
Unfortunately, path names which special characters contained are not supported by data translators in general. This is a known limitation, I must admit.
Hth
Thomas
Thomas Rausch
Software Development Manager
wild-hunt
Ah, yes, sorry, didn't recognize the root level folder "Selbstständigkeit", which I created several months ago, before I started using it also for Alias file exchange. Thanks, Thomas!
