Alias CONCEPT 2020 crashes when switching workspace
Message 1 of 16
Dear all.
Since yesterday my Alias CONCEPT 2020 frezzes and crashes as soon as I change the workspace.
Can some help?
Leon
Replies (15)
Message 2 of 16
bob55
Could you post the workspace file.  And does it crash on any workspace, for example "AliasClassic"?
Message 3 of 16
Dear Bob55.
First I could send you two screenshots of what happens. And yes, asap I switch to Alias Classic, first it freezes and then it crashes with "the blue spinning circle" of windows. Then I have to restart via the task manager.
Where do I find the file?
Idea: Could it be possible, that Alias has trouble with my resolution of windows? Because now I am working at home, on my small 22" screen but with my "workstation" and at the office, I have a whey bigger screen of 29".
Anyway, the issue appears since a few days and I didn't change anything besides the resolution of windows.
Message 4 of 16
That is the exported file by "workspaces / export workspace".
Message 5 of 16
bob55
What is the scale and resolution of your monitor?  Also if you save a workspace out and retrieve it back, do you still crash?
Message 6 of 16
Currently Im running a EIZO 22" with 1680x1050 and at the office a DELL 42" with 4K.
My graphic card is Nvidia Quadro P5000.
Message 7 of 16
A few minutes ago I installed Alias Concept 2021...same story. I copied the PrefSet, went to "My lounchtime workspace, windows changed (fine) and the I wanted to move my "Modeling window" aside to correct my workspace window (F8) and again... freezing and crash.
Message 8 of 16
bob55
Please zip up your UserPrefs directory and post it.  You can find it here...
%APPDATA%\Autodesk\Alias\UserPrefs2020
Also, I'm assuming you are running Windows 10.
Message 9 of 16
Correct.
Message 10 of 16
Here is the ZIP
Message 11 of 16
Dear Bob.
Obviously I am not able to drag a ZIP-file here. Don't know why. Do you see a second chance to send it to you?
If I use WETRANSFER, the link will automatically be disabled by the admin.
Update: When I launch Alias, my workspace is in default. When I choose "Workspaces / Leon Workspace", Alias chrashes. Spinball appears. Different happens, when I go "Leon Preferences / Leon". Then everything is good.
But anyway...something is really strange about the whole situation: It is a fresh installation and somehow it chnges itself after while I feel.
Leon
Message 12 of 16
bob55
You've found a strange problem.  It's been around for a while.  I've entered a ticket, but in the short term it seems you can't have your Multi-lister collapsed down or up when Alias launches.  If you do Alias will hang when you try to import a workspace.  If you un-collapse the Multi-lister then import the workspace, all will be fine.
Message 13 of 16
Sounds really strange.
Message 14 of 16
NO, the solutions doesn't really work.
Message 15 of 16
bob55
It's important that you don't have a collapsed Multi-lister window in the workspace your loading.
Message 16 of 16
Ok so having the "shaders lister" or "multi lister" opened / collapsed in general is the problem? Strange but it works somehow. But when I save a workspace save, such without the lister, how can I fix my working window in the right position? My toggle cube is always hided by my control panel (see attachment)
