Alias can't open WIRE/EDF - only grey workplace
Hi, I have problem with Alias. I downloaded 2017 version, later also 2015 version because that one we have in school.
My problem is simple - I open any .wire but see only gredy background. The whole software works smoothly, no problem in clicking on menus etc. but I can't see anything in the workplace. Background is grey, stays grey and even the cube dissapeared.
I tried exporting the .wire into .edf, but even this I can't open.
I tried downloading 2015 version as I thought there might be problem opening old .wire to the new 2017, but the problem is still the same.
I really ran out of options. Today I reinstalled both version but nothing changed.
It's worth saying, that the files I try to open can be opened anywhere else, on other computers it works great.
My OS is Windows 7 64-bit Home Premium.
If you have any working solution, feel free to add it.
Thank you
Have you tried the reset view tool ?
Where do I find View Pallete? I don't have anything on the workspace.
Thanks for reply
I see... Perhaps you can try to clean install all your existing Autodesk's products.
Kindly follow the instructions in the following page:
Clean Uninstall
Well I did clean install 3 times, I don't think there is the problem.
Just want to confirm, you did the clean uninstall by deleting all the residual file ?
I did the clean install followed by the guide I found earlier before you sent it. Maybe I found solution which is pretty stupid, but works.
I have Alias on SSD, but all the data I store on classic HDD. I was pretty angry, so I copyied .wire to Desktop and try to open it from there. It fcking worked! So there must be problem with Alias and more discs in computer. I tried to open it from flash disc - didn't work, also tried external HDD - worked.
Any idea?
